B
Bruley88
Hi all
I'mhaving trouble with a new instal its a spilt board 10 way DB
first half of the board has
down stairs lights
upstairs sockets
boiler
second half
kitchen
upstairs lights
and down stairs socket
The problem im having is the downstairs light in the hall is tripping the both rcd when turned on, I then removed the circuit from the rcd and wiring straight into MCB not touching the rcd just to fault find.when light is then turned on the rcd which is used to be run through doesn't trip but the second half of the DB trips the rcd although this rcd has nothing to do with the downstairs lights.
I have checked the factory wiring which runs from neutral terminal to top on both rcd each rcd neutral then runs to its own bar. I wired the circuit straight into the neutral terminal where rcds get there neutral feed from but still tripping second rcd.
sorry for rubbish explanation im a three phase and panel guy so this is abut out the ordinary for me any help would be great appreciated.
down stairs lights
upstairs sockets
boiler
second half
kitchen
upstairs lights
