telectrix
Mentor
MK have designed a prototype CU for domestic use in follow on from the metal CU debacle. The lid has a multitude of posidrive heads, coupled via an 1000V insulated shaft, to all the Main Switch/RCD/Mcb Teminal screws. these heads are ground breaking technology as in that they contain a heat sensitive chemical which is green under normal temperature and pressure, but changes colour to red if the temperature exceeds 45 degrees C. there fore, any householder with a pozi screwdriver can thus tighten up any loose connections without the need to open the CU or phone an electrician. The estimated cost of a 10 way split CU is in the region of £2495 inc. VAT. Oh, bugger. it was the first yesterday.
You tried one yesterday and it didn't work either....
don't care. it's all just in jest. better than doing the gardening or asny other jobs that she who must be obeyed wants.
telectrix
Mentor
cheshire/staffordshire
United Kingdom
Electrical Engineer (Qualified)
Business Name
Telectrix
New Development from MK
Electrician Talk Forum
Thread Tags
Tags Tags
new
telectrix,
telectrix,
