M
Mattrod
Greetings.
Just done a PIR using the new EICR form, and had a few questions regarding the inspection.
The main bonding is in 4mm and the main earth is in 10mm. Is this a code C2 or C3? There was a thread for recommendations for PIR's on here which is pretty good, so I am going to stick to these guidelines.
I take it C1 requires urgent attention, and C2 is not needed to be so urgent but will have to be improved. What is C3? Does not comply to 17th edition? No laballing (ie mixed colours)? It says "improvement recommended" .Just a bit confussed. But, saying that,I find quite alot of ambiguous stuff within the regs and concerning part P and all that....
Any help would be greatly received
Cheers fellow sparks!
