New electric shower, with rewirable replacement mcb | on ElectriciansForums
Discuss New electric shower, with rewirable replacement mcb in the Australia area at ElectriciansForums.net
A
animox
Hi Guys
I got to connect a new shower up to an exsisting circuit, that is on its own circuit protected by an old rewirable replacement plug in mcb.
Should I replace this with an RCD?
Cheers
You don't actually HAVE TO, unless RCD protection is required by the manufacturer’s installation instructions, or a new circuit is required (to provide for increased load, for example).
Personally, I wouldn't dream of not adding RCD protection, even on a like for like swap.
Regulation number(s)
134.1.1 510.2
that, IMO, would be the ideal solution. don't forget, if you are fitting a shower CU, you will have to fully test the circuit as well.
Reply to New electric shower, with rewirable replacement mcb in the Australia area at ElectriciansForums.net
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
