New Electrician asking for help with a shower please? :) | Page 2 | on ElectriciansForums
Discuss New Electrician asking for help with a shower please? :) in the UK Electrical Forum area at ElectriciansForums.net
C
Catch22
Hi guys and gals,
I recently went to a customer's home and disconnected a shower ready for a plumber to come and install a new shower cubicle and re-connect the pipes for the shower. When I came back I found the cbale was now to shoort so had to include a new piece of cable to reach the shower. As it was an older installation I decided to add in a DP isolator pull cord, means of isolation etc and so forth. A few weeks later the customer is coming back saying that the shower is cutting out at the MCB after a few minutes of use.
The shower is the same as is the cable run to the isolator. All that's new is the cable from the isolator to the shower. I can't figure as to why it would now do this considering it's the same shower and power supply?
I have yet to inspect the shower again, but didn't want to go in looking like a complete idiot as I'm sure you can all understand so wanted to try and get some advice prior to getting there.
Many thanks in advance!
Dan
I'd guess that the new shower and old shower are the same make but different KW rating.
Plumbers mistake possibly.
Some showers come in several ratings, e.g. 8.5, 9.5 and 10.5 kW, though it ought to be obvious when buying it, as the prices will vary (quite apart from being marked on the box). Unless someone was asked to buy one and not told the old rating. Or perhaps thought it would be nice to have a bit more power and not think it mattered at all.
Reply to New Electrician asking for help with a shower please? :) in the UK Electrical Forum area at ElectriciansForums.net
Me personally wouldn't replace it without rcd protection.
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
