New Electrician asking for help with a shower please? :) | Page 3 | on ElectriciansForums
Discuss New Electrician asking for help with a shower please? :) in the UK Electrical Forum area at ElectriciansForums.net
C
Catch22
Hi guys and gals,
I recently went to a customer's home and disconnected a shower ready for a plumber to come and install a new shower cubicle and re-connect the pipes for the shower. When I came back I found the cbale was now to shoort so had to include a new piece of cable to reach the shower. As it was an older installation I decided to add in a DP isolator pull cord, means of isolation etc and so forth. A few weeks later the customer is coming back saying that the shower is cutting out at the MCB after a few minutes of use.
The shower is the same as is the cable run to the isolator. All that's new is the cable from the isolator to the shower. I can't figure as to why it would now do this considering it's the same shower and power supply?
I have yet to inspect the shower again, but didn't want to go in looking like a complete idiot as I'm sure you can all understand so wanted to try and get some advice prior to getting there.
Many thanks in advance!
Dan
get a clamp meter on it . clamp round main incoming L tail. turn off all other breakers. turn on shower. read current, then compare current with In rating of the MCB. if it's not more than 30% over and the MCB trips, then the MCB is goosed. ssimplesss.
Reply to New Electrician asking for help with a shower please? :) in the UK Electrical Forum area at ElectriciansForums.net
Me personally wouldn't replace it without rcd protection.
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
