The course is with OLCI. It is part home study part college and the NVQ part is on the job as an electricians mate.
Once qualified I plan to look for employment somewhere before eventually starting out on my own. Course is as below
Fully Qualified Electrician
City & Guilds 2330 Levels 2 and 3
City & Guilds 2356 NVQ Level 3
This course package will enable you to work on: domestic jobs, commercial projects, maintenance jobs or you could work in media organisations or sports entertainment and events. You will be able to work for yourself or gain full-time employment as an electrician
Theory Units: 2330 City & Guilds Level 2 & 3
Theory- 5 Units which are completed via home study with a personal tutor available to contact by phone, fax or email should you need any assistance. At the end of each unit, a multiple choice assessment will need to be completed and returned to your tutor for marking. You will need to complete the first 3 units before you start your practical workshops.
· Working Effectively & Safely in an Electrotechnical Environment
· Principles of Electrotechnology
· Application of Health & Safety & Electrical Principles
After successful completion of the above units, you will need to successfully complete the assessments for one of the two occupational pathways:
1) Installation (Building & Structures)
· Inspection, Testing & Commissioning
· Fault Diagnosis & Rectification
2) Electrical Maintenance
Practical Workshop: 2330 City & Guilds Level 2 & 3
Practical- 23 Days which is split between workshop training & assessments. You can attend your practical workshops and assessments at your convenience which gives you the flexibility to complete your course and become qualified as quick as you like depending on the time that you choose to or are able to dedicate to your course.
Practical training workshops will cover the following categories:
Level 2
Electronic Circuit Theory
Series and Parallel circuits
Ohms Law principles
Single pole relays
Open and closed loop circuits and Sinusoidal wave forms
Further Hand skill development for building electrical wiring systems and electrical enclosures, which cover single core and before PVC sheath cable
Metal and plastic conduit and Mineral Insulated Copper covered Sheathed cable (MICCS)
Set to build circuits and enclosures using FP200 cable, Steel wire Armour (SWA) and Steel Trunking, ultimately combining all these skills to produce and Electrical Composite Installation.
Level 3
· Installation theory
· Applications of Electronic circuit theory
· Build & construct various Semi conductor Transistor control circuits
· Applications of Domestic, Commercial & Industrial environments
· Inspection, Testing & Commissioning of Electrical Installations
· Applications of BS7671 British Standards for the purpose of Testing Electrical Installations
· Fault diagnosis & rectification of electrical installations
NVQ Level 3 Qualification – You will need to gain work experience and be assessed on-site to get your City & Guilds 2356 NVQ Level 3 Electrician qualification. If you don’t have access to on-site work, we may be able to assist you. While we cannot guarantee to secure a position, we will do our best to help.
Course Total Cost: Flexible ÂŁ5,858.85 Inc VAT
