New fixtures for outdoor lights | on ElectriciansForums
Discuss New fixtures for outdoor lights in the UK Electrical Forum area at ElectriciansForums.net
You’d need the appropriate masonry attachment for the tool you are using. Also very dependent on how hard the brick is. May be easier to pin drill the area you want to remove and the use a masonry SDS attachment to clean up the edges.
in conjunction with a SDS drill with rotary stop. easy peasy:
[ElectriciansForums.net] New fixtures for outdoor lights
Reply to New fixtures for outdoor lights in the UK Electrical Forum area at ElectriciansForums.net
You actually need to use the light switch since that’s where the lights are controlled from. The red wires should be your travelers going to...
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
