NEW Fluke 1653b tester RCD Displays lead for a second on first rcd trip test | on ElectriciansForums
Discuss NEW Fluke 1653b tester RCD Displays lead for a second on first rcd trip test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
Crisp1987
Hello
Has any one got a fluke 1653b tester or experienced the same thing with another teser. I have just bought a brand new fluke1653b tester. When i carry out a standard rcd test the first time the rcd trips on my meter the word "LEAD" flashes up for about 1 second, could be less, and then the disconection result is displayed as it should be. but it only does this on the very first trip.
I dont think this is a fault but it is a little strange. Has any one had this before?
Reply to NEW Fluke 1653b tester RCD Displays lead for a second on first rcd trip test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
