about time and well overdue. Still don't really see why you need a fluorescent for working on a roof though, what's going to run you over up there! I only require it if guys are having to work or go into a traffic area for access or to collect materials. Also I think they should have made mention of the use of helmets to protect against falls, but also to protect workers on the ground from possible falling objects. Also helmets should be used with a retaining strap.
Flourescents are good on the roof for avoiding accidentally knocking someone with a rail etc particularly when it's getting towards dusk.
helmets... on the roof I find they are more of a hazard than anything else, though I guess maybe with a retaining strap at least they'd not fall off every time you tried to get under a panel to do the wiring etc. I reckon we've lost more helmets off the roof than anything else when we have worn them. Anyone working below the scaffolding though should have a helmet on all the time IMO - though my spark appears determined to ignore that rule until something actually does land on his head, the amount of times I have to tell him about it.
Flourescents are essential, as they make the ability to indetify individuals easy. On our larger jobs, we use different coloured flourescents and different couloured helmets, and with a swift glance I can see whose in charge / responsible for what and so can everyone else. On small domestic jobs being able to see / identify where people are is equally beneficial. Helmets are a moot point when on the roof untill someone drops a bracket on you when you are underneath the scaffold fetching the clip you just dropped.
we try to remember to have helmets at the base of the ladder to be put on when anyone comes down from the scaf - also good for customers who decide to stand outside watching you working.
fluourescent on the roof, waste of time IMHO. I know who my guys are, what they do, and where they are!! It's following the lemmings without thinking it through IMHO. Wearing a fluorescent increases heat degradation and restricts movement. I've seen the results of enough ladder falls to be absolutely persuaded a helmet is essential, and a waste of time and a hazard in itself without a strap. What head protection do your guys have going down the ladder if the helmet is at the base! Surely the most risky time is climbing down the ladder, for knocks, falls and being hit by objects. If you wear a helmet at no other time wear it when your going up and down the ladder! If your losing helmets they are either the wrong helmet or not being worn correctly. The standard site type helmet is totally unsuitable. You need a proper working at heights helmet, with a retaining strap and no peak so you can look up unobstructed. We also have a clear agreed instruction of 'BELOW' if something is dropped,, which comes from the climbing world. If your spark doesn't wear his helmet when you tell him to it's still you in the dock. I'm sure being sent off site will help reinforce the message! But then, what I think actually doesn't really matter. If you can stand up and justify it in court then your in the clear.
From this photo, I know exactly who is who and where they are. - flouro's essential .....
Gordon, if your so safety conscious why have none of the workers on that roof been supplied or required to wear Gloves, none are wearing eye protection, both are now legal requirements, and has that one actually working ever been on a Manual Handling Course, because clearly he will wish he had been if he keeps lifting stuff like that...
Oh by the way, technically (and I know it is an unwritten rule) but the only recommended Hi Vis clothing for construction environments are the horrible lime green ones. The Orange are technically for track side work, high speed carriageway and in docks or air side. I know they are used in many environments these days, but then many HSE "rules" are applied as it suits employers rather than common sense.
how do you mean, legal requirements?
It's a legal requirement to ensure they're available for use if required, and to require your worker to wear them when needed to protect against hazards.
It's not a legal requirement to wear eye protection or gloves the entire time while on site, especially not while stood around waiting for a briefing, as I assume was the case here.
blanket rules about you must do this, you must do that are not what H&S are about, it's about making an intelligent assessment of risk. You do not need to wear eye protection the whole time you are on site, you need to wear eye protection when doing something that may be a hazard to your eyes and the level of protection should reflect that risk, so the eye protection for grinding will be different to the eye protection for a splash hazard. The use of gloves may in fact increase the risk of accident due to reduced dexterity. It depends on what you are doing. Likewise eye protection can become a hazard in certain circumstances. Your supposed to use your noggin, not blindly follow supposed 'legal' requirements. You assess the risk, then take the appropriate steps to mitigate the risk.
Thanks for making the point others made about Hi-Vis vests....all you have to do is adjust the goal post for others to walk through... :D
gloves probably wouldn't be a bad idea, but maybe not a necessity depending what the material of the thing is he's holding, eye protection... why?
Considering the roof has a loose surface that can be kicked up accidentally I would suggest that all those on the roof should have eye protection with them and anyone actually working would be well advised to use it. I am not one for blindly insisting on the use of PPE regardless, but there are some situations where people be given it and they should be instructed to use it where there is an increased risk, failure to use it should make them liable and NOT the employer.
We all know that a good risk assessment and method statement (rams) will determine what will be PPE specific for the project in hand. As been stated all ready, glasses and gloves would be applicable if it were mine.
But I am deviating from your original point as to the use of hi-vis vests; as the photo you supplied for example shows; It hightens workers visabliity present around you, especially on your peripheral vision.
Looks like there would have been a few panels going on in that space,,,,, makings of a nice little number there :)
the wearing of helmets when on a roof is essential. a frozen turd from a 737 at 31,000ft comes with quite an impact. same as flying pigs.
ooh, better remember that next time I walk down the street. I'll wear my eye protection. Actually, thinking about it, I probably ought to wear it when I go to visit my parents as well, as they have a gravel drive. It's a miracle I haven't blinded myself yet!
you just stated it's a legal requirement for eye protection and gloves to be worn, which you're now back tracking from without stating that this is what you're doing.
they're not legal requirements as a general rule, only in circumstances where they're needed, and then it's a judgement call - you judge a gravel surface to be dangerous enough to need eye protection at all time, I beg to differ, but if that's what you're comfortable with and what your method statement says then by all means enforce that on your guys, just don't make out that this is some sort of legal requirement as it isn't.
PPE is always made available including gloves and eye protection. Safety briefing's methods statements and tool box talks are all regularly undertaken. And yes they all go on manual handlining courses and have current CSCS cards... - All for example were today taken through the new new HSE guidelines leaflet and given a copy of it.
The key thing is though that we don't find that CORRECTLY applied safety measure either hinder the work or cost more. The costs of accidents are far far higher, in lots of ways.
New HSE Solar Guide
Thread Tags
SRE,
muzza1,
