New kitchen electrical safety question | on ElectriciansForums
Discuss New kitchen electrical safety question in the UK Electrical Forum area at ElectriciansForums.net
Crewe
I've just had a new kitchen fitted and the installer came out several months ago before work was due to start and checked out what needed doing and at that time he never advised me that I needed extra power plugs.
He started the work last week and advised me that I would need to purchase a 5 meter extension and run it round the back of the kitchen to the dishwasher as there isnt a plug.
I wanted to get some advice if this is safe and if the installer should have taken the time to install the extra power point.
if you have payed to have a new kitchen fitted and electrics done at the same time then, as above, I would not be happy with having an extension lead for the dishwasher. A socket should have been installed for this.
I'd say that there is no safety issue with an extension lead, as long as the lead is the correct length and rating for the dishwasher. It's just shoddy. You payed for a new kitchen so you should get one...
Yes someone came out and designed the kitchen and confirmed where each appliance would go, when he designed the kitchen he never mentioned about additional power points were needed. Then another person came out to check to make sure everything was ok and again never advised that additional points were needed.
Think I am going to complain.
Check the paperwork on the original quote and order, it should state weather the electrical works are included or to be charged extra etc.
Who did the design? When I did the electrical install for a kitchen refurb, the kitchen designer position the appliances. It was then down to me, as the electrician, to ensure there was suitable points/supplies for the appliances. If the kitchen supplier did the whole thing, someone like Magnet, they are sometimes responsible for the whole lot,
But did it not occur to you? The mind boggles.
Not everyone thinks about electrical points... Most would not know or bother about the details but just expect a proper job to be done.
Why should he? He has paid someone to install a brand new kitchen for him. Why should he ask if there is a socket for the dishwasher? Should he have asked if there is a feed to the cold tap also?
When having a large job done such as a kitchen it is a good idea to sit with the designers explaining what you want. Positions of sockets is pretty important, not just for a dishwasher but for all the other small appliances as well.
Yes but a customer shouldn't have to think about the designer not putting on a socket for each appliance. Most people would assume that it is a given.
Reply to New kitchen electrical safety question in the UK Electrical Forum area at ElectriciansForums.net
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
Sure, I'm on the Isle of Sheppey. also the cable they used I think was 2.5 twin and earth, although I could be wrong.
