New Lighting Circuit | on ElectriciansForums
Discuss New Lighting Circuit in the Australia area at ElectriciansForums.net
Hello, is it ok to power a new lighting circuit, eg new conservatory, from a fused spur which is spared from a socket ring circuit back in house??
yes it is allowed,
if you look in appendix 15 page 362
the diagram shows fused spur with 1.5 cable linking to double sockets, (as you have reduced the cable size you need to add the spur.
If you decide to wire the lights in 2.5 cable you could omit the spur (I wouldn't and I haven't omitted it in my conservatory
Richard
The cu is at other side of house and its a big house. I thought a new lighting circuit had to be fed from an existing lighting one, didnt think you could get supply rom socket ring, but if its fused i guess its ok.
Reply to New Lighting Circuit in the Australia area at ElectriciansForums.net
There's a difference between being required to install an RCD and being required to have a full rewire when all the houses around have similar...
The 3A fuse is there to protect the current lighting. For additional power you connect from the non protected 3A fuse side.
