B
bluehawaii90
Hi Guys,
I've just joined as i'm sure you can see. I've got what i hope is a really simple question regarding a dpdt switch. Can I wire it up to be used as a spst switch?
I've made a record player and i've hooked up a dpdt switch which works fine, it's just off when the switch is in the "on" position and on in the "off" position. Currently i believe i have the wires (both red) connected to 1 and 3, I ran a multi meter across the pins and they were the only ones that bought back a reading.
Like i say, it's probably a really simple answer, i just can't work it out! I've tried different combinations but none seem to get it switching on/off the right way.
Thanks in advance,
Lauren.
Thanks in advance,
Lauren.
