G
gordysolar
Does this inverter require 100ma type b protection and also array earthing back to a rod what size earth wire needed?
Discuss new model sma 3600tl- 2 in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
It's fanless, relying entirely on convection cooling up it's heat fins on the back to cool it.
I can't entirely decide if this is a positive thing or not
they're not immune to the basic laws of the speed of capacitor degradation relative to operating temperature though, so better to keep them cooler if possible.The working parameters of all SMA inverters are large in regards to temperatures.
you do realise I'm an installer, not talking about my own system?If you are worried about your loft getting hot and the inverter overheating why not install a fan on a seperate circuit, to turn on under a predifined solar load or inverter system temperature.
This relay could also be used for alternative reasons, i.e turning on an immersion circuit under certain inverter power output conditions.
and yes, we've installed 15 of them this month, and about 60-70 4000TL's so I'm well aware of their capabilities. i was just pointing out about the fanless nature of the 3600TL as I've not seen it publicised anywhere and it was a wee bit confusing when we opened up the first one to find a missing fan.
they're not immune to the basic laws of the speed of capacity degradation relative to operating temperature though, so better to keep them cooler if possible.
As convection currents are entirely reliant on the temperature difference between the ambient air and the heat fins I can see the ambient air temperature being more important here than in a system that has the option of switching a fan on to boost the air flow across the fins. I could be wrong, but this would be my working assumption until someone shows me that I'm wrong.
Reply to new model sma 3600tl- 2 in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
