New motor for Xpelair pRemier DX180H? | on ElectriciansForums
Discuss New motor for Xpelair pRemier DX180H? in the UK Electrical Forum area at ElectriciansForums.net
London
Hi all,
Please could someone advise if it's at all possible to get replacement motors for extractor fans - specifically for the above!
I've taken the old one apart and wired the motor directly up to 240 as part of bench testing & it won't run. It's been struggling for several weeks to get running and then falters intermittently - shaft spins freely and I can't see how to measure ohms on the windings as it's a micro motor and well taped up. With the direct feed applied I'm sure the motor has gone.
Have had a search but can't find replacement motors only other bits!
I'd like to use the same model as it saves a lot of making good and decorating!
There's one on eBay for ÂŁ50 but before I opt for that I was just wondering if it's possible to get other spares than just grilles and impellers!
Cheers muchly,
Dilalio
Cheers chaps.
No cap on the motor and data label rated at 230v.
Cap on the pcb and it has humidistat wiring, but I measured volatage at the motor terminals first and that was reading circa 240 volts.
Audible buzz between all terminals on motor and got ohms reading across them too not O/C but could not get any life into motor.
I'm pretty sure it was shot but no stats available to check against.
It's been in an giving good service since 2008 so not a bad buy in the first place. Getting the one of eBay for ÂŁ50 seems the most plausible route to go!
Keen to learn... why would there be 3 wires to motor terminals (red, brown & blue)? They all Terminated in a pin connector onto the pcb but only the brown and blue connected onto pins from the pcb; red was isolated in female of connector! For a different model perhaps? What would it have supplied to the motor on the opposite side to the other terminals?
Many thanks,
Rather than attempting to repair it may be cost effective to replace with a newer model. Contact the manufacture or look into the product technical information, the newer models may well have the same dimensions, fixing holes, cable entry. I've found this to be the case with some other manufactures.
Sigh.
Found a Dx200T on eBay for ÂŁ70.
Newer model with delayed start more powerful motor, Timer and "same dims and fixing holes".
Will be here tomorrow.
Cheers All.
Was my overall plan but am always curious about dead elec motors. :wink:
Reply to New motor for Xpelair pRemier DX180H? in the UK Electrical Forum area at ElectriciansForums.net
I would agree that the motor is by far the best part to replace. if it is powered and not turning then it is broken. Keep it simple!
Complete guess, but it's probably cheaper to let a separate meter read a CT clamp and send the data to the charger's microcontroller using rs485...
