New multifunction tester | on ElectriciansForums
Discuss New multifunction tester in the The Welcome Forum area at ElectriciansForums.net
Bracknell
Hi, I'm obviously new. I'm looking at buying a fluke 1663 but am concerned that when the new 18th edition comes in it will be obsolete. Would I be better off buying a used 1653b, + calibration, and then a new mf tester when the new regs come in?
If this has been covered then please feel free to post the link, I have had a look but couldn't find anything on this subject.
Also, to say hello to everyone. I will be looking at gaining some much needed advice and hopefully give some as well. My background is as a sky installer and working with home automation. I have been going out with a few electricians over the last year to try and understand what I learnt in the classroom, c&e 2330.
Obviously when new Regs or ammendments arrive you have claims of testers complying to the new requirements which they do, but in truth nothing will have changed.
Cheers for the responses Westward10 and Telectrix. That's good to hear. It's expensive enough, without being told that the new equipment is now out of date!
Think I might go for the Fluke 1664fc, purely because it has the 'insulation pretest'. Anyone know if this really does work and shows up attached equipment or is it just a gimmick with lots of disclaimers?
I don't know the details of this meter, I can only assume an "insulation pretest" applies a reduced voltage and if it senses a certain resistance across the circuit it stops a full test, bit like dipping your toe in the water.
Test on 250v and you'll see if there's attached equipment......
or clamp the L out of the MCB before dissing. any current in the cable, there's a load attached.
Reply to New multifunction tester in the The Welcome Forum area at ElectriciansForums.net
As a trainee, one of the things I've tried to focus on to deepen my interest in the world of electrics, is the space for creativity. I've...
