J
joolzhaines
Hi,
I have asked an electrician to give me a quote for installing a new external power and light to a shed and power and light to an open patio area and have a few concerns with his proposal and wanted a second opinion
Thanks for your advice I just don’t want to get ripped off for work that is not needed.
Regards
Joolz
- He wants to run 30mm cable to both areas which seems very large cable for a couple of lights and plug sockets, I would have though 10cm would be enough
- He wants to put a RDC fuse box in the shed and patio area to feed to sockets which I think is overboard? The main consumer unit has RCD’s already and the new circuit will be on its own MCB covered by a RCD
- Will having a fuse box with RCD mean that if there is a fault outside it will not trip the house RCD?
Regards
Joolz
