New planning rules from 6th April? | on ElectriciansForums
Discuss New planning rules from 6th April? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
solarcat
Hi All,
I've just been told by a local planning officer that a new set of rules concerning solar will be enforced from the 6th April. Unfortunately she said she did not have the new set of rules yet. Does any of you know know where to access them? How will our life change after the 6th April?
I have seen the draft today, it appears more for commercial.
They have taken down one hurdle by relaxing planning, but put up another by requiring an EPC.
Basically, this was as I understand it, on a commercial roof if you install and leave a minimum of 1m on all 4 sides, you can install under permitted rights, also on a flat roof you can install up to 1m from the plain of the roof.
Ted will put us right. (he beat me to it)
Has anyone thought through what the phrase, "..... on a roof and within 1 metre of the external edge of that roof;" means?
Is it effectively just the verge or hip (sides) rather than ridge (top) or eaves (bottom)?
Regards
Bruce
Well that's good news in a way - if it's just going back to a farmhouse built since the 30's with natural gas or a biomas boiler then it makes it easier.
I know, it's just ridiculous!
Anyways, what I don't understand is...after the 6th of april will PV on a block of flats with a commercial property on ground floor become permitted development?
Yes, as long as you meet all the other conditions that apply to permitted development.
Previously that would not have come under the definition of a block of flats, but from April 6th it will fall into the 'everything else' catch-all that is used in the new legislation.
Part 43
A. The installation, alteration or replacement of solar PV or solar thermal equipment on a building other than a dwellinghouse or a block of flats.
where the definition of “block of flats” is a building which consists wholly of flats.
Thanks Ted M, translating Legal into English is not everyone's piece of cake.
Local council here still say that we need to apply for planning, and they want to charge a small fortune for it:tearsofjoy:355! So I'd better wait until the 6th April and simply not apply!
what is article 1(5) land?
"(e) in the case of a building on article 1(5) land, the solar PV or solar thermal equipment would be installed on a wall or roof slope which fronts a highway;"
also, how did you find out about this, have i missed some communications? Isn't this something that our governing body should be informing everyone about??!?
Article 1(5) is a term that refers to National Parks, Areas of Outstanding Natural Beauty (AONB), The Broads, conservation areas and World Heritage sites.
This just applies in England at the moment.
It's also worth reinforcing that this applies only to "microgeneration" so systems over 50kW would still need planning approval.
...Still no update on Planning Portal and local council completely unaware of new rules! Any advice on how to prove that the new planning regulations are now applicable?
Reply to New planning rules from 6th April? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
My girlfriend has a cousin who has lived in Japan for at least 15 years teaching English yet he can barely speak their language.
    • Informative
Hi, I previously read this but can’t find it. I have drilled some holes but haven’t found it yet. Before I instal the wires I thought I’d check...
