C
carlito79uk
I am looking at new wiring for a conservatory and cannot extend r spur from anywhere, so my only option is to add a new circuit from the consumer unit.
The 2.5mm twin and earth will come around the outside of my house (in conduit approx 15m) and into the conservatory
Below is the digram of connection i intend to use, i also intend to connect it in the consumer unit to a 20amp mcb.
Off the first switch fuse socket on the diagram will be a security light which will be connected via a normal flex about 4m and off the final switch fuse socket i intend ot have some pond electrics (using armoured cable approx 10m length run)
Could you please tell me are there any obvious errors or does everything seem acceptable.
Many thanks
Many thanks
