Davey1988
just installed a new shower in a block of flats. the flats does not have a RCD to protect the installation in the CU in the flat. (Not sure in electrical room for whole building as could not get access).
The Shower cabling is surface mounted but all the other cables in the walls i would of through need RCD protecting.
Im completing the Test sheet and says whats the RCD protecting the installation. Do i just put N/A?
Cheers guys any help aprichated.
