B
beats
Good evening,
I have recently completed a new built 4 bedroom house,now time for 2nd fix, the client wants sky hd in the lounge and the master bedroom, with the other 3 bedrooms and the kitchen to have freeview and the same channel as sky in the lounge. I have run 3 coax's too the lounge and two coaxs to all other points.From the sky dish a shotgun cable goes to the lounge box.
From what i have read up on i will need the two cables from the master bedroom to go to the LNB of the dish to give that room hd , then an aerial/antenna cable to the lounge sky box and connect one of the coaxs to the rf2 out to feed an splitter/amp in the loft to provide freeview/one channel sky to the other points is this correct and is there any recommendations on the loft mounted aerial and splitter.
thanks chris
thanks chris
