New to PAT Testing | on ElectriciansForums
Discuss New to PAT Testing in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
UK
Hi. I have just become a PAT tester. I'm new to the business and also using forums. Wanted to just see if there is an advise or wisdom that could be passed on. I have my potential first customer with 300+ items and would like to do my do diligence.
Took the course to as to my CV, but the current job I have is quite flexible so I can squeeze some more work in.
Hi Martin, welcome to the forum. First customer with 300 or so items, that’s a biggie. Before you go on site, find out what types of items you will be testing and in what environment. This can vary greatly, e.g. we do mostly entertainment industry testing, which is generally all in one place, whereas testing offices or hotel bedrooms is the opposite of that. You may be testing all BS1363 13A stuff, but you may also come across other connectors, so find out in advance and make up short jumpers to cover everything you may encounter. The various moulded IEC320 adaptors you can buy for a few quid on eBay are useful to have. Find out if there’s fixed appliances you’ll be expected to test under ISITEE. If you’re going to be testing plugtop RCD adaptors, get an isolation transformer, so you don’t trip upstream RCDs/RCBOs. There’s a few ideas for starters.
Best piece of advice I would give you is charge a decent price, get a Tester with bluetooth software that records and stores all the items and customer details for their records . Also a barcode item printer and scanner will save your loads of time on you repeat visits and will automatically update to the items list for your customer records.
Thanks for that. It is a doctors surgery, so you know the environment I'll be going to.
I have put myself together a kit. I have a seaward 100 pat tester. I bought a thermal bar code printer to make my return visits easier. I purchase a 5 piece adapter for my IEC lead. I purchased a kewtech kamp12 4mm mains test lead 13a plug adaptor and test probes and crockadile clips which I bought for testing my cooker. I've purchased seaward 110 adapters 16a and 32a which I've purchased for testing construction tools when I get a job. I've purchased BS 1363 plugs, fuses, some ext leads. So I can offer a replacement of one is needed.
The first thing I questioned was the ECG machine which was covered with both PAT testing stickers and Williams medical stickers. I looked on Williams medical website and they pat test aswell as calibrate and there sticker indicates that they come out once a year. I contacted the Pat tester to ask if they PAT tested in accordance with IEC 62353 or 60601 and the person who answered the phone said hymn Im not sure. To sum that up. I'll be telling the manager to stick with Williams Medical for this, along with any Medical equipment that falls out of the scope of COP 4th Edition.
I have also bought a copy of the IEC COP 4th Edition which I'm making my way through. Surprised the course I did didn't supply this as it appears as it's the go to book in this business.
The training course I went on was good and they answer any email I send. I had a fail on my washer dryer for the leakage test. Results were 3.74ma. They answered back that on the Seward blog it says that as the leakage test is optional an allowance of 10% can be allowed. So I was happy with that quick help out.
In the surgery that I will be working there are no stickers on the hand dryers. This surprised me as I'd say they fall under the scope of PAT testing.
You've both sent me slot of help and I thank you for your fast answers. I'll have a good look at what you've wrote and research it. Thanks again.
I sat a 50 question multiple choice exam, and demonstrated on 5 different appliances. My certificate doesn't say C&G 2377-22 on it. Just that it is based on the COP 4th addition
You sound fired up and ready to go - good on you.
My advice, take some sandwiches and a drink and try not to comfort eat because it’s so boring - I can take one afternoon of it then I’m done!
Seriously, all the best with it. You sound prepared and professional.
Why this thing about stickers? You are not obliged to put stickers everywhere and they are easily abused. I sometimes have to do appliances in holiday homes and I provide them with an appliance register and a detailed pass and fails schedule as per the code of practice. I print these out so that they can be displayed somewhere on the premises for those interested.
I suppose it depends on the environment. I only do 'in house' testing of all the equipment on the guys vans. A lot of the sites we work at insist on visible stickers.
Martin, do you know that there's another MB Pat Testing local(ish) to you. They are over in Bristol. Could get confusing for people looking you or them up :confused:
@mhar . The 'stickers' that I used were a thermal barcode that identified the item for the next inspection and automatically updated my records that was then emailed to them via my software .
I do not do them any more.
LOL I get asked to do a bit of PAT Testing now and again. Charge properly for it or it's pointless doing it. I wouldn't entertain doing it without a downloadable PAT Tester though.
Reply to New to PAT Testing in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
I used to do a lot of this. My go - to was testing at the load side of isolators etc where possible. Although of course you'll find plenty of...
out of interest UK, how do you know what kit is connected?
Hi Avo, Thanks for the reply. Think that's what i'll end up doing. The cal cert says everything is fine but i'll get a better picture once start...
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
