New to the forum just wanting advise on a sensor in a bathroom | on ElectriciansForums
Discuss New to the forum just wanting advise on a sensor in a bathroom in the The Welcome Forum area at ElectriciansForums.net
Yorkshire
Hi
Basically I just want to know what is required to fit a sensor in my bathroom and do away with the light switch completely. I'm having a new stud wall built with a pocket siding door inside the wall. So the joiner said I'd need to get a pull down light switch so there would be no wires in the wall where the door wood be inside a metal frame. I don't like the idea of a pull down and prefer the sensor . Any advice would be grateful , I'm not an electrician but surely if I switch the mains off it wouldn't be a big job??? The other wire that runs down the wall is going to the thermostat on the pics, that has to be removed to .... thanks
The picture is of a surface mounted detector,there are flush ones available
I believe the type you are fitting will require a neutral
Small changes like this are usually well within the capability of the average householder,but because of the change to the wiring,it may come under the silly Part P building regulations
More importan the IEE wiring regs requirements for circuits in or passing through this special location need to be met and could involve quite a lot more than just a different type of switch
You need a sparks for this one mate. For what it will cost it's not even worth the hassle of trying to do it yourself. Better off paying and know it's done safely and the right way.
So long as you have a neutral at the current switch (which from looking at the wiring without seeing the connections, does appear probable) then it should be possible to make this change as you are simply repositioning an existing arrangement, however the position of the sensor should be such that it is not within the zones of the bathroom and ideally there should be 30mA RCD protection to the circuit.
Richard,my eyes not being of a age that make them anywhere near reliable :)
Even so they are seeing single core and earth cables to that switch he posted
edit
I just noticed flat cable,I better get back to that opticians anytime soon :)
Yes, one of the earths is very dark green and I thought it was a neutral, it does look like single cores. Not quite so straight forward then, new feed from the light required, gets more complex.
Thanks for the replies, the switch is still in use by me only when I'm there. Other then that no one touches it, it all broke away when taking the wall down. Ok sounds more complex then I thought, sometimes you just think is it a job to small to ask an electrician or could I mange on my own given the right advise... hence the reason I joined this forum, is there something wrong with this wiring des??
If there are other people in the house (and for your own safety, it's all too easy to stumble and reach for something to stop yourself falling, especially when working), please, please, replace that switch today.
Hi,hopefully,you ripped out,with the power off. I have removed acres of lath and plaster,and none of the tools used,were made of rubber...
Either way,your switch will be full of gritty dust,ideal for arcing,and even more fun,seeming "off" whilst in the "on" position.
Please attend to those matters,before selecting new switch gear. :)
Reply to New to the forum just wanting advise on a sensor in a bathroom in the The Welcome Forum area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
