A
alienware
hi guys, This is my first post here. I tried to post in the DIY section but some reason I can't add a thread there. I'm thinking about buying the smart glass film system which comes with a 12 to 110v convertor. My question is considering the circuit will be run off a 15000 mah 12v battery using a 12-110v convertor is it likely fatal if someone were to touch the 110 v wire. If it's highly dangerous I won't bother with it. But if it would most likely just give a small jolt and is relatively safe then i'll buy it. I've currently made heaps of circuits from 12v batteries which don't zap me but I've never jumped the voltage to 110v. I'm not using it near water but it is possible that I might accidently touch a live wire while setting it up / testing it. Thanks in advance. Mike.
