Just been reading this forum and found this
"I did fit my fire, then I had a qualified person come in and do the pipe work to it so I knew it was safe".
Just let us know your Gas safe "qualified person" number and we'll report him for contravening the gas regs. It's not allowed for a reason and it's the same as electrical work. Many people don't understand the problems that they can introduce by even doing "small electrical work" All electrical work has to be certificated for a reason and if you are an engineer you would understand the reasons why... Many people have tried to help here and all I can advise is that they shouldn't give advice to unqualified people. Many fatalities are caused by unqualified people, be sensible and get quotes from professional installers.
Read more: http://www.electriciansforums.net/p...nergy-forum/69634-newbie-3.html#ixzz2MHa2LwtI
not with the changes to part P coming in soon. A totally backward step IMHO!
Why would you ever think that you are qualified to hang a fire? are you Gas Safe registered? are you at least Part P qualified?
I guess I know the answer from your attitude. People have been trying to help you here, their intentions are good, your intentions seem rather dangerous.
Gonefishing I think you should re-read all posts. This is someone who on a limited budget wants to improve the environment for us all. By just reading his posts it is obvious he is competent to carry out the part of the job he is doing. The remainder he is either taking advice or getting it certified.
You on the other hand appear to have little or no knowledge of the requirements of part P.
Little update, the front aspect brackets and bars are on. Most of the rear brackets are also on, just waiting for the chimney to come down this weekend to finish up and then it'll be time for the panels :-)
Thanks for your comments, It's ok for you then if he gets it all wrong and isn't qualified to do the work and ends up killing someone. There are many here who have paid hard earned money to do the work properly. If you had any idea of the costs for becoming an installer you wouldn't even comment something so ridiculous. The posts show he is not compotent at all as he is asking! and I'm sure my knowledge of "Part P2 ourstripes yours easily.
Gonefishing - go fishing :59:
I've just read all your (19) posts and haven't found one that doesn't find fault with the topic being considered, additionally you have yet to post something that would actually be helpful to any of the threads...
Chimney has gone. Flued ridge tile in its place. Also got the rest if the brackets on the rear aspect. If the rain holds off tomorrow, I'll be getting the rest of the bars on and then the scaffolding can be moved ready for the panels to go on :-)
System is all in! Just need to buy some padlocks and put the labels on then i'm ready for inspection :smiley2:
Well done, who is inspecting it?
Also your AC switches need to be lockable in the off position, but it is not a requirement to own the padlocks.
I've got a local installer who's been working with me through the install in to do it. Have grabbed a couple of locks anyway, just so everything is there.
I didn't have the cash to do mine only choice for me was to us homesun to do it for free or get in to debt and I am not doing that over solar
And both of us at home all day to use that free power! I bought a solor-log 200 wifi (datalogger) and set it up using SolarAnalyzer Pro it come in android and windows. I use it on my nexus 7 tablet and can see real time power stats.
Anyone know how to alter the tariff on PvOutput.org?
Mine will be 13.99p but it seems to be defaulted to 45p.
Interesting to see that the East & West systems are outputting almost the same kwh. Will have to check sometime my exact orientation.
Quick update, just over 3 months on and have produced 3385kwh. The West orientation seem to be marginally better than the East at the moment, but there's not much in it.
Another quick update....have now got an Immersun heating a separate cylinder to supply our hot water as our boiler can't accept preheated water. Water is heated to 80°c, is pumped through a heat exchanger to heat the incoming mains and the resulting hot water passes through a blending valve to give us hot water at the taps. 2 solenoid valves controlled by a top of tank stat controls which source the hot water comes from. In 5 days, the Immersun has put 50kw into the water :-)
Hi Steve ,
Good to hear that the systems performing well.
What's the difference between preheating the water and the HEX? Is the HEX in advance of the boiler or is it after? Do you 'assume' that the primary source is the preheat tank if so why bother with the hex and not just blend the output from that tank? - Care to post a schematic of the plumbing and controls, (confused) thanks.
Am using the cylinder as a heat store only and using the HEX to give me mains pressure hot water. It's a vented cylinder. The boiler will alarm if you try and feed it with preheated water. Will try and draw up a schematic when I get in from work. Am looking at a speed controller for the pump now rather than the blending valve to see how efficient I can get it. That said, the return back to the tank is cold so it's probably not worth it....but I do like to twiddle :-)
Righty, hope this comes out ok.
The tank top stat controls S1 & S2. If the tank is above the stat value ( 48c ) then S1 opens and heats the HEX, if below...S2 open and the boilers fires. Should point out there is a flow switch where DHW is on the drawing which is a live feed to the stat...then DHW. Both valves are normally closed. Using this system due to having a combi condensing boiler which wont accept preheated water but still wanting mains pressure hot water without the need to get a specialist in to fit a pressurised tank. Works a treat!! ;-)
OK, I see what you've done, now let me put my thinking cap on.
I reckon we might be able to use a solar controller with it's variable Δt values and multiple pt1000 temperature sensors to give you what you need.
What you call a blending valve I presume is a Thermostatic Mixing Valve as normally installed on the the outlet of DHW cylinders or on the inlet to bath taps etc.
Couple of points concerning the water regs:
I am not sure also that the 2 port valves you have used are suitable / legal for potable water - I presume you used 'normal' 2 port central heating valves?
Also from the regs point of view it looks like you missing a check valve as well.
More normal practice would have been to convert your combi to a system boiler and use an unvented cylinder - then as you realised you need to be G3 certified to install / play with / configure those as otherwise they are literally bombs if not installed correctly.
Hi Gordon, the 2 valves are proper solenoid valves, bit like you find in a washing machine, but bigger. The blending valve is indeed a TMV and I'm looking at a Gledhill GT152 pcb with sensors to possibly control the pump ( lots of these boards around so keeps the cost down ).
Steve, still got my thinking cap on.
Couple of things to watch you'll probably need a Warwick flange Warwick Flange - Search Results | Screwfix.com on the top of the cylinder to stop air being pulled down the expansion pipe (often used for shower pumps) . The store should have a separate feed from the feed and expansion (f&e) cylinder (your 'open topped tank') else you could end up circulating cold water from the f&e round the heat exchanger and so cooling the vented thermal store.
More to come..
There's also this which, so lang as the combi can take 24° would work, though at a retail price of £354 it's a killer! (trade nearer £200 inc vat) Grant Combisol Solar Water Heating. Combine Your Existing Heating With A Grant Solar Heating Solution | Grant UK
Will use solar heated water, or if not hot enough, will send to combi or blend it down for combi, so uses the maximum possible heat out of the thermal store. So, if the store is > 29° then run the HEX pump (allowing for a Δt across the HEX), water will be heated to whatever it can reach it can then either go direct or blend down if nescessary for the combi - means you don't need the solenoid valves, and it uses whatever heat is in the thermal store even if not up to usable temperature directly so maximises the use of the 'free' heat. So now all you need is a flow switch, stat and pump...
However, since you've already invested in what you've got so far ..... then need to find another way to do that :). If you were just starting out it may have been the easier solution.
I've been very fortunate with the kit I've picked up, mostly from EBay over the last 8 months. Everything I've bought new but even so, its come in at a fraction over £300. I spoke to Glow Worm about my boiler before I started, and was told catagorically that it wouldn't accept any preheated water although they couldn't tell me the max it could take ( hmmphh ). Looks like we are using about 8.5kw/day of hot water inc heat loss. Nice to actually use some of what I'm producing and a free long and hot soak feels sooo much better!
Been back on the drawing software to draw up what i actually have in the loft. My first drawing was my plan....it has evolved :thinking:
There is no vent pipe as i'm not actually using any water from the tank and expansion can still easily take place back into the header (did take a while to fill mind you!!). So basically the HW tap is turned on, this activates the flow switch which in turn puts power into the top tank stat. If the water is above 48'c in the tank, then the stat puts power into S1 and also the pump. 85'c water is then circulated around the HEX to heat the incoming mains and this in turn is mixed with more cold water using a TMV to bring the temp down to a more reasonable 45'c to supply the house. If the water in the tank falls below or hasn't reached 48'c then the stat opens S2 instead of S1 and the boiler works as normal. Both solenoid valves (S1 & S2) are normally closed when there is no HW demand.
Have picked up a Gledhill GT152 pcb (pump speed controller) today to see if i can use the pump speed to control the DHW temperature rather than a TMV as at present i've had to partially closed the pump gate valves to restrict the flow of water through the HEX because even on the slowest pump speed, my return water to the tank is too warm. With the valves partially closed, it is cold. Will keep you informed :smile:
You could really do with a double check valve on the DHW exit from the Hex to stop potential reverse flow in the event of S1 failing.
You should also consider a potable water expansion vessel on the DHW Hex loop as you do have a closed volume of water (I know it's less than 15 ltrs)
AND (apart from the fact that you should should budget for a new boiler in the near future ..) Although they wont admit it, the way your boiler works it should cope with pre-heated water:
I believe The GlowWorm's thermistor is on outlet of hot and flow switch on inlet.
So it should require no mods to boiler. She's not allowed over 65 and the Thermistor will shut out burner once at 58. So initially to combi will flick in but then it will drop out as the store pre heats. As you've done, heat the store to max of 85c run it across plate so the plates always hot and ready to go - use one of those grunny smart pumps with a remote pocket stat on hot outlet on plate. Bring cold via a double check into plate then tmv down on to DCW inlet on boiler at max of 65c (or 45° as you're already doing though in that case the boiler will probably fire up to continue heating...)
Unfortunately Glowworms don't have the best rep on the market, so when it comes time (probably in the not to distant future :( ) to replace it, better to consider and Intergas, Atag, Ideal Logic + or a Baxi Duo-tec 2 as I'm pretty sure all of those can take pre-heat.
If you don't want to run the risk of trying the preheat on your existing boiler, rather than shutting off the HEX completely, you could also blend down the heating INPUT to the HEX using an underfloor heating thermostatic blending valve myson do one so you recycle a proportion of the output from the hex back to the input so reduce the temperature of the inflow.
(p.s. for anyone else considering something similar get hold of a Baxi 105E and rip its guts out - almost all the components you need are lurking in there somewhere, including a nice pcb with a variable pump speed controller )
Beware unless you are GSR you must not touch the insides of the boiler.....
I do have 2 mini potable expansion vessels in the system, they are about gratefruit size, one is on the HEX side of S1 and the other is on the heat input side of the flow switch ( fitted to stop any chance of hammer). Will look into the check valves athough if a solenoid failed it would be sprung shut. Would rather play safe though so i'll see what the local merchant has got in
Quick update.......have gone from £106 per month for gas & electric in my pre solar days to £43 per month with the solar and hot water setup. All this and I get around a grand a year! Win win.
Would recommend a solar install to anyone, even with today's lower rates.
Newbie
Thread Tags
Tags Tags
newbie
Steve_rutland,
Steve_rutland,
