NIC Forms Forms Forms | on ElectriciansForums
Discuss NIC Forms Forms Forms in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
Peter Woodford
hi everyone
does anybody know if there is a book that helps with filling out nic domestic forms or can anybody help with the following
1. Characteristics of primary supply type is this HRC Fuse that goes in this and were do i get the sort circuit capacity from
2. on test results do i put 0.4 s in max disconnection time 230v domestic install
3. Design, contruction inspection and testing what do i put in after bs7671 amended to
4. main switch rated current i take it this is main switch in board 100amp
thanks
There is a book available from the NICEIC on Inspection and Testing and filling out their forms.
ITC - Inspection, Testing andÂ*Certification 17th Edition | NICEIC Direct
1. Distributors cut-out fuse either BS1361 or BS88. Max KA will either be 33KA or 16.5KA depending on type 1 or 2.
2.All depends on the circuit in question
3.BS 7671 2008 has not been ammended yet so N/A.
4. It will either be the Main Switch in your consumer unit or if you have a sub-main to yout DB from the main intake then the rating of the Sub-main isolator needs to be recorded also.
were do i get the ka ratings from and type 1 or 2
thanks again
Guidance Note 3 ISBN 9780863418570 &
Practical Guide to Inspection and Testing ISBN 9780750684491
Both are for the C&G 2391 exam covering all aspects including form filling
Chris
Hi Pete did you pass your NIC assessment 4 wks ago ?
Soz just recapping.
Regards
Kung.
Yes passed thanks have just also been asked to do a pir for someone they are buying a house I under stand u don't have to be nic to carry this out is that right just have to be comptent do u know how much to charge for one of these
Reply to NIC Forms Forms Forms in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
