niceic domestic or niceic full scope | on ElectriciansForums
Discuss niceic domestic or niceic full scope in the Domestic Electrician Forum area at ElectriciansForums.net
M
michufc
hi i am regestered as a domestic installer with the niceic just wondered what the differance was with the niceic approved contractor or did i need any other certs
cheers
the main differences i know about are
you can work on commercial and industrial
give a nic cert when you do a pir
like jason said give nic a ring im sure they will have all the info your after
just another point i think you have to be trading for 2 years to become a approved contractor maybe wrong though
hope this helps
If you go onto the NIC website
NICEIC Direct Search - Find an Electrician
click on the "Contractors" Tab and then "NICEIC Schemes" there's information and downloads on both the approval process and gaining approval - there's also the contact numbers at the bottom of the page if you want to give them a call.
Cheers
Will
Sorry,
just seen that url has auto inserted a link that takes you to the wrong page
it should say niceicdirect - you'll need to put in the www and .co.uk at either end of to make the link work. (Sorry had to do it this way to stop the url auto insert problem )
Will
http://www.nice
http://www.niceicdirect.co.uk/
Guys,
DIS approval through the NICEIC allows you to carry out domestic electrical installations and register them under Part P through oursevles as a registered scheme provider for Part P.
You can issue domestic electrical installation certificates and domestic minor works certificates with the NICEIC approval on them.
Any other work can be carried out by you but you must either issue a green certificate or a certificate based on the model forms from rhe BS7671.
However those scopes of work are outside the remit of your NICEIC approval.
NICman.
Reply to niceic domestic or niceic full scope in the Domestic Electrician Forum area at ElectriciansForums.net
NICEIC Certification Scheme NICEIC Competant person scheme
This sounds very similar to me. My level 3 NVQ is in engineering maintenance and I also have a HNC in Operations Engineering. I’ve been working...
I have not missed it on the website as I know the background to it Unfortunately from information posted on this forum a number of years ago I...
