NICEIC EICR form is wrong?!?! | on ElectriciansForums
NICEIC Certification Scheme NICEIC EICR form is wrong?!?!
Discuss NICEIC EICR form is wrong?!?! in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
E
Eddiesparks
The NICEIC EICR form has, on 7.7 of the schedule of inspections the following tick box:
'Recessed luminaires...installed to minimise build-up of heat by use of 'fire-rated' fittings, insulation displacement box or similar'
The bit i dont get is the mention of fire rated fittings. Common misconception isnt it that fire rated means they wont catch fire if you bury them in insulation(!!) - doesnt it just mean that the fire rating means they hinder the spread of fires upwards from room to room. I believe this tickbox is inaccurate and misleading. Am I on to something here?!?!
So i'm doing an eicr and it's top floor flat with no habitable rooms upstairs. Not fire rated downlights. This is fine and was not going to record a fault. but do niceic expect me to find a fault on this tickbox?! Why?
Ed
I believe NICEIC have added this section to their own forms & its not in the model forms.
I suspect they mean the fire hood or inbuilt material in fire rated fitting will activate before a fire starts in ceiling.
I wouldn't worry about the wording but would worry about cheap open fittings with no protection.
The certificate is following BS7671, Fire Rated fitting can also comes under building regs; what i assume the cert covers is fitting that are required to be fire rated according to the BS7671 and not where they don't maintain the rating of say a plasterboard under building regs but do comply to the 7671.
If the 7671 states the fitting require to be fire rated in their set-up then X the appropriate box.
Even if they are on top floor?!
Depends what crap is above ceiling & if therefore fire risk. Could apply to a bungalow.
ESC guide suggests C2 for incorrectly "installed" or "selected" downlights.
Of course it's up to inspector on site to assess the risk.
Reply to NICEIC EICR form is wrong?!?! in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
