Niceic technical help | on ElectriciansForums
Discuss Niceic technical help in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Talked to the tech line the other day hoping to confirm what I already knew, but with a definite answer regarding issues on EICR, on a property 40+ years old.
Not a great experience I must say, putting all the onus back on me, What do you think you should do?
At the end I gave a very conservative answer on the issues, saying well I wouldn’t be doing this NOW would I?
Guidance Note 8 talks about bonding in multiple occupancy dwellings and from memory is clear each flat should have extraneous services bonded to the MET in that flat at the point they enter that flat.
The question is more about the 6 sq mm CPC of the distribution circuit supporting the bonding I think.
Yea the problem is the CPC to the flats…that require MBPC..
The Meter positions are remote & are individual to each flat & so are the Water supplies to each flat & are extraneous parts.
No easy install for a new Earth Conductor & doubt if the LL would pay for it to be done
Reply to Niceic technical help in the UK Electrical Forum area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
