night storage heaters | on ElectriciansForums
Discuss night storage heaters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
bristol
hi everyone,hope you all are busy!
I have a night storage heater to look at,customer has said it is cold,am thinking could it be the thermal cut out switch just needs to be reset?.will test heater on a temp supply.
Cutouts cutout for a reason....usually heater covered by someone drying clothes....or input stat sticking.
As above...ohmeter test at heater terminals with local isolator off....open circuit-heater problem.....approx15-20 ohms-heater should work so suspect supply fault.
Check how old it is because if it is 8-10 years old sometimes the combined control/high limit module keeps tripping I have been doing work for a letting agent and their "other" electrical company seems to like reseting the high limit and the majority of the time it is tripping due to wear and tear and their not pleased as they are paying them for return visits when they should be repairing the unit. I have attached a photo of a Dimplex control/high temp cut out[ElectriciansForums.net] night storage heaters
I got some bits off them last week for a couple of creda storage heaters, nice easy site I got the customer to order the bits as it was for a mate, have to phone to order as no online ordering that i could find.
Reply to night storage heaters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Assuming this was done, but if you happen to be looking again around here, I am Oxford based.
I am a landlord/owner of a flat. I am just about to spur off nearby sockets to provide the additional 24hr supply to new Dimplex Quantum storage...
