Im doing a cu change, installing 2 new ccts and some minor alterations to the existing ring in a basement flat. This ring has one double socket which is on a spur but I cant find the connection between ring and spur anywhere. The cable goes down behind the skirting and I suspect it goes into the concrete floor. The cct is old so probably before the days of maintenance free JBs. IR test is fine though.
I am relocating two other sockets on the ring and the plan is to fit a FCU on the spur to feed two more sockets.
Can I sign this off or is it too big a departure from to regs? Do I need to break the floor up?!
Thanks in advance for any help with this.
