No bathroom RCD | Page 3 | on ElectriciansForums
Discuss No bathroom RCD in the UK Electrical Forum area at ElectriciansForums.net
Dorset
Some numpty has put in a ceiling fan with a pull cord above a bath - ceiling is getting very damp and apparently water keeps dripping out, I guess due to condensation in the duct.
Customer (tenant) wants me to put in an in-line fan, and as it doesn't have a fan isolator switch, add an appropriate switch.
Old Wylex board, TNCS.
My thinking is what I've been asked to do doesn't infringe current regs. Fan is outside the bathroom, my only query is if I put in a pull isolator switch for the fan, is that required to be RCD protected? If so, can put a switch outside the bathroom just below the ceiling above the door. In which case no concealed wiring and not in a special location.
Thoughts? I would prefer to put in a pull switch! Have also suggested the tenant tells the landlord that CU upgrading would be a good idea.
Not sure which book but I know 100%
That's OK then. :lol:
Basically it's common sense some of the regs. Eg if you have no window you can't see without a light so you need an isolator to keep lights on
By that logic, it would be impermissible to install an in-line fan in a loft unless there were also a loft light installed so that you can see to maintain it. :rolleyes4:
There's exceptions to everything really, so you would still be an isolator. And a touch, but you can't do everything the same way, like a tt system and a tncs requirements are different as to zs
Which part of that reg requires a local fan isolator ?
Reg537.3.2; devices for switching off for mechanical devices (is an electric fan a mechanical device?). Reg 537.3.2.1, 'notes' gives examples for switching off for mechanical maintenance; multipole switch, circuit breaker, CPS, control switch operated contactor & plug & socket.
Reg 132.15.202; Every fixed electric motor shall be provided with an efficient means of switching off, readily accessible, easily operated and so placed as to prevent danger.
Thats for a bloody great lathe or a conveyor, not a piddling bathroom fan.
[ElectriciansForums.net] No bathroom RCD
Reply to No bathroom RCD in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
