No clue how to solve this... | on ElectriciansForums
Discuss No clue how to solve this... in the UK Electrical Forum area at ElectriciansForums.net
I
Indirestraits
In all honesty I have no clue how to even approach this...
A generator is connected to a high voltage line through a Δ-Y step-up transformer T1
A Y-Δ step-down transformer T2 is connected at the receiving end of the line to supply a motor load. The rating details are as follows:
Generator: 30 MVA, 13.8 kV, XG = 0.10 p.u.
Motor: 20 MVA, 13.8 kV, XM = 0.08 p.u.
Transformer T1: 20 MVA, 13.2 -132 kV, XT1 = 0.10 p.u.
Transformer T2: 15 MVA, 13.8-138 kV, XT2 = 0.12 p.u.
Transmission Line: ZTL = j100 ohms (actual
Use 30 MVA as the base and draw an equivalent circuit (impedance) diagram showing the individual per unit values. What is the magnitude of load current in the motor?
Show the calculations you have done so far.
We will not do your homework for you. The whole idea of homework is to make you think for yourself.
BUT have a look at the last line of the question, there is a major clue in there.
Reply to No clue how to solve this... in the UK Electrical Forum area at ElectriciansForums.net
