A
ash_s3
Found out the hard way on a job today the lighting circuit for the whole house has no CPC.
I understand its ok aslong as all light fittings and switches are class II, RCD protected, sticker on DB etc.. but what about the pins on switch plates? surely if the backbox were to become live so would the pins holding the switch to the wall!
Do i need to fit switches with covers over the pins?
Also the loft light is wired in bell wire (2 core 0.5mm) can i just disconnect it from where its taken from and advise customer its not safe. Or do i just fail it on the test sheet? Dont want to leave it in.
