No cpc on light circuit - class 2 lights? | on ElectriciansForums
Discuss No cpc on light circuit - class 2 lights? in the Australia area at ElectriciansForums.net
A
andyww
Hi all
I have a customer with no cpc on the lighting circuit - property is a top floor flat with a flat roof above so no access above ceilings. I was looking at the possibility of installing class 2 lights - I've found lots of websites offering class 2 fittings but it's unclear exactly what comes with them. Can you get a simple class 2 rose and pendant? If so, does anyone know where? Other question is on the switches, can you get class 2 switches? and again, if so, where?
Hi all
If I not mistaken the normal bog standard ceiling rose as it comes is Class 2.
Not so sure on switched but I'd guess at the normal basic white plastic switches could be class 2. I'm not sure if you would have problems with metal back box and metal accessory screws?
Jim
Im A NICEIC qualifying supervisor and would advise you to fail this installation as it does not comply with current bs7671 reg's without looking for the reg because its Sunday, all live conductors in PVC/PVC require a C.P.C (circuit protective conductor) all final circuits i.e Lts need a C.P.C any problems and i will look it up for you.
Hi Gaz - me too, and I have failed it. The customer has asked me to provide a solution to the problem - I have said it needs rewiring by either replacing with new T&E or pulling a seperate CPC into the circuit. The challenge is that there is no space above the ceiling, so if any cables get 'lost' when attempting to pull new ones then I have a real problem, only resolvable by pulling the ceiling down. The ESC best prcatice guide states that if the fittings are all class 2 then it is not a fail. Just trying to understand exactly what constitutes a class 2 fitting, and whether this could be a cheaper and less intrusive solution.
you are correct. There are 2 best practice guides that deal with this issue - one is on changing a consumer unit when you have light circuits with no cpc, the other is the periodic inspection report guide that clearly states a code 2 (unsatisfactory) should be assigned to a light circuit with no cpc containing at least one class one fitting - I assume from that, that if the circuit contains only class 2 fittings then it is satisfactory, hence my original question?
thats harsh, you dont know what the op is doing to the circuit. if class 2 fittings are used throughout i cant see a problem :confused:
work through the flow chart on the best practice guide and come to the correct conclusion.
all current installs dont HAVE to be brought up to current spec
Thanks for all the advice chaps, but on a practical level: If I fit class 2 throughout the circuit and place the relevant warning sticker on the consumer unit, am I then correct that the installation can be given a 'satisfactory' rating, albeit with a note on the certificate indicating no cpc on lighting and the fact that class 2 equipment has been installed?
True True but at the end of it u have to put your name in it, But If class 2 is used through out and documented in the report just to cover your back just in case DIY Sparks decides they want a nice shiny brass bling bling fitting.
blimey, youve changed your tune :rolleyes:
the other alternative is to take the moral high ground and keep telling all your customers that their houses need rewiring and lose the work to me ;)
if they cant afford/dont want a rewire they are quite within their rights to source someone who will carry out the work they want done.
bearing in mind i havent see this particular job i would advise if all double insulated fittings are used then crack on :p
I don't do house bashing so u can have the work, hence the reason i said no no, because we all know random people come and change fittings so it could cause a problem. its only my opinion but what do i know, i'll stick to process control sorry boys :eek:
Reply to No cpc on light circuit - class 2 lights? in the Australia area at ElectriciansForums.net
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
