O
Octopus
OK, lets have a decent discussion about this as I'm sure there will be a number of opinions!
Have done an EICR on a 40 + year old flat. The lighting circuit is wired in singles and utilises the steel conduit as the CPC. Out of the 6 lights and using my R2 wander lead, only 2 have an acceptable reading - the remaining 4 have 200 ohms
The CU is a dual RCD and there are no metal fittings or switches
So do I:
A: Suggest a "no CPC" label be added and give a "satisfactory" ?
or
B: tell the owner the lighting circuit needs a rewire and give it an "unsatisfactory"?
Tin hat on!
So do I:
or
Tin hat on!
