NO CPCs | on ElectriciansForums
Discuss NO CPCs in the Australia area at ElectriciansForums.net
stidge
Nottingham
Just a quickie lads,
any advice greatly appreciated,Customer needs new CU upgrade,also earting to gas and water.Happy with my price but informed them up/down ltg ccts need rewiring no CPCs!!!!. Customer cant afford this ,i have explained about metalllic switches,fittings etc(which they have none at present). Question is can i replace CU test and cert and make warning notice on CU that no CPCs on LIghting cct,no metallic fittings etc etc ??????????:confused::confused:
You can replace CU. Just as long as there is no class 1 fittings. You will only be making it safer.
Reply to NO CPCs in the Australia area at ElectriciansForums.net
