Discuss no earth external plastic in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
What would be the consequences of someone swapping for metallic one?I know it's bad practice but.i opened up a plastic light fitting 2 stories up on the external wall and there's no earth just line and neutral.i feel it's okay but is there many reasons this is bad
I don't quite agree. The cable doesn't need a cpc. Every point in the wiring, however, needs a cpc.if it's a class II fitting, it does noe need a cpc. however, the cable should have a cpc, even if it's not connected to the fitting.
In an ideal world yes, unfortunately in some cases lighting was wired with twin no cpc.I don't quite agree. The cable doesn't need a cpc. Every point in the wiring, however, needs a cpc.
is that not the same thing? unless a separate cpc is added.I don't quite agree. The cable doesn't need a cpc. Every point in the wiring, however, needs a cpc.
Agreed, but check out 543.6.1 which I think says it should be nearby.I don't quite agree. The cable doesn't need a cpc. Every point in the wiring, however, needs a cpc.
What does nearby mean? next door, in the CU down stairs, come on guys get real don't take it literally, it's real life not fantasy land, nearby, for crikey s sake.Agreed, but check out 543.6.1 which I think says it should be nearby.
I could walk on it, if I really concentrated, cus I am a God.like I'm nearby to the Mersey, but not actually in it. I'd get my feet wet just walking on it.
Sorry to have offended you by use of the word nearby.What does nearby mean? next door, in the CU down stairs, come on guys get real don't take it literally, it's real life not fantasy land, nearby, for crikey s sake.
Indeed, but the point is that a separate cpc can be drawn instead of using one incorporated within the cable. (Indeed singles wouldn't be usable otherwise.)is that not the same thing? unless a separate cpc is added.
Reply to no earth external plastic in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
