M
michael_brooke
Hi guys
Today i went to look at a communal light to test, and found that the light was wired from the dno fuse carrier with a 2.5mm twin and earth to the light with no isolation but the 6amp fuse in the carrier, my question is, is this ok as i cant find anything in the bgb that states otherwise or does it need a 2 way cu installing so that the circuit is protected by mcb. Look forward to the positive feed back
