No lights upstairs! | on ElectriciansForums
Discuss No lights upstairs! in the DIY Electrical Advice area at ElectriciansForums.net
A
Alexspeight
Hi
Instead of my lighting circuit being (GGG) (R) (BRR) (BB)
I actually have (GGG) (RRR) (B) (BB)
The light circuit 'was' working, however I went to change the end fitting and found this, now it doesn't work and blows the main fuse.
My problem is, I do not know which is the mains feed, or the circuit, or switch wires.....
ANY help would be appreciated.
Alex
if i were a hippopotamus , i could wallow in that mud. just call a local electrician.
Live pair in, live pair out, live and switched live down to the switch
Your weeing in the wind without any test equipment. Just get someone in who knows what they are doing.
Yes mate I tend to agree with you, you can throw all sorts of advice at someone who is obviously not competent and it will make nil difference, OP get someone in who knows the score.
he's in portsmouth.
Reply to No lights upstairs! in the DIY Electrical Advice area at ElectriciansForums.net
Question 1 do you prefer buttered, salted or sweet salted? I'm guessing salty 😜 1. Auto range multimeter (used on mains before when testing the...
The lights are on a circuit with other lights, which is a different circuit from this receptacle. Both of these circuits and others are on the...
