No mains present... alternatives...? | Page 2 | on ElectriciansForums
Discuss No mains present... alternatives...? in the UK Electrical Forum area at ElectriciansForums.net
Uk
Power is required for a roller shutter garage door...however were the garage is located, there is no means of getting 240v power
What is the alternatives...?
A roller shutter door, with a decent flywheel, operated by an endless chain, will open and shut with no effort and as fast as an electric door.
The only advantage that I've found with electric ones, is that you can push the remote fob from fifty yards away, and the door's fully open by the time you reach it.
We had three of those around 15' high and 12'wide, never a bit of trouble in over 20years , and still in good order when the building was sold.
Reply to No mains present... alternatives...? in the UK Electrical Forum area at ElectriciansForums.net
Sorry, it’s a proposed installation so neither of those options would be possible until the install is actually complete by which time it would be...
If you think that's bad you should try manually winding out the safety curtain in a theatre.
davesparks
