Hello guys, I am using Shinko BCS2R00-00 temperature controller for a packing machine. The indicator shows that the output is on but there is no voltage output from the controller output terminal. So, the mould was not heat up. I have change to a new temperature controller, but still have the same problem. I would appreciate some help. Thank you.
