L
LankyWill
On a site which use air source heat pumps for all the heating and HW. They have underfloor heating throughout and mixers. They have a "Specialist" connecting all cylinders, hot water tank, expansion valve etc to the unit outside. Now its a Sweedish System installed and the ufh firms bloke has been on the course to certify and connect up the system. I first fixed the system and he is doing the panel part- its a smart plc system. Now, he has NO official quals not even... plumbing!!!
I turned up this morning to find his tank strewn across the floor as when he filled it with 80 liters of water his 1" screw fixing to plaster gave up. He then leaves the panel cover off LIVE and goes home, everything wonky and looks like a child/ blindman has put it up. The wiring centre looks like a Electrical Trainee best attempt and he is is on ÂŁÂŁÂŁ because apparently he is a "Professional"- he isn't even scam registered. Beggars belief, am i being pedantic or should i be worried?
