A 4 Pole 30 ma RCD, supplying a 4 pin socket, the circuit has no neutral, RCD tests fine phase to earth and works as should apart from the functional test button not working due to no neutral or resistor. Thoughts on a link from earth terminal to neutral incoming terminal to enable the functional test button to work.
