No Rn loop on ring | on ElectriciansForums
Discuss No Rn loop on ring in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
shocked
Hi all
this may help as it took me a little time to find
when testing an existing ring main i found it had a broken Rn ,so i took the sockets off and tested between them and found that the MFI electrician a couple of years earlier had connected one Rn with the switched load side of a spur fuse so when the switch was on Rn loop ok when the switch was off no Rn loop.
thought it may make easier for some of you next time your testing, switch on/off sw fused spurs
john
i had similar thing other week-cowboy kitchen fitters been in and ring ended up been connected across two breakers.
What did they say to justify that?
Protected twice now isn't it :)
Thats the problem with diluting the trade to all trades :(
Reply to No Rn loop on ring in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
