No Spare Way for Shower Can Move Doorbell to Share Lighting Circuit or put Doorbell on Switch Spur? | on ElectriciansForums
Discuss No Spare Way for Shower Can Move Doorbell to Share Lighting Circuit or put Doorbell on Switch Spur? in the UK Electrical Forum area at ElectriciansForums.net
N
Novice12
Hello,
New builder and Electrician started today to wire-in electric shower to wire already in place for it.
They phoned to say that the new consumer unit that old builder's Electrician put in, which is a 10-way, has no spare way for the shower cable which wasn't wired in.
I spoke to old Electrician who said can move doorbell so shares a lighting circuit to free-up way for shower cable.
Told new builder and Electrician about this and was told can't share circuit.
Went back to old Electrician who said can put doorbell on switch spur above fuse board with 3 Amp fuse so not sharing circuit.
Not got hold of new builder and Electrician to suggest this to them yet but wanted to know if they are right that can't share circuit like old Electrician first suggested and whether putting doorbell on switch spur which was his second suggestion is an OK solution re. regulations etc.
As Westy says - fcu from ring would be ideal. To be honest if it was unavoidable I'd run it from the lighting circuit, same as I would for an aerial amp in a loft if need be.
Daz
I thought the sharing bit was, dividing the work between the old electrician and the new electrician. Dear me, leave it to the new electrician, or get the old electrician back in. :)
You could get one of these;
Then ask if the new electrician is happy with free way that's now been unshared!
Thanks all for your responses.
The new Electrician is saying that circuits must never be shared.
he's a dick then.
the citcuit would not be shared. once the doorbell was added to the lighting MCB, both would become parts of a single circuit. what about smokes being put with a lighting circuit, as most of us prefer to do.
Ask him for his solution to the problem without upgrading the board. If he says there is no other option it is likely he is just set on trying to part you from your money, in which case you should part him from your company.
Reply to No Spare Way for Shower Can Move Doorbell to Share Lighting Circuit or put Doorbell on Switch Spur? in the UK Electrical Forum area at ElectriciansForums.net
Me personally wouldn't replace it without rcd protection.
Better off with the click prw213 as it has twin screw termination.
