NO switch insulation resistance failure | on ElectriciansForums
Discuss NO switch insulation resistance failure in the Talk Electrician area at ElectriciansForums.net
sysrq
uk
How often do we usually have insulation resistance failures on an NO switches leading to unexpected starts?
Reply to NO switch insulation resistance failure in the Talk Electrician area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
