M
meddyliol
I am connecting a cable from the consumer unit to a double light switch. Having connected it to the consumer unit and before connecting to the switch I tested the mains voltage. There was 250 volts at the consumer end but my meter (Fluke) was only reading about 7V at the other end of the cable which is only about four feet long. Testing with an ohmeter gave zero ohms so the cable seems OK. Any help would be appreciated.
Brian
Brian
