Noisy main cold water pipe, my plumber hasn't heard this before. Hi Folks,
Would like to cast the net far and wide to try and get some resolution to this problem. The mains water coming into the property via a 15mm copper pipe, I have a Worcester Bosch Heatslave 15/19 around 16 yrs old to which the mains goes into - just above the boiler our plumber fitted a pressure valve to limit the pressure going into the boiler as we kept blowing the flow meter in the boiler every couple of years and we restrict the pressure to 3.5 bar. (property of down the side of a valley so we have mains pressure plus gravity). The noise would happen ranging from around 40 seconds to a couple of minutes usually mornings or evenings so we were checking the appliances that were running and what was being used in the bathroom etc, for a pattern. However the last 3 times this has happened it's been early in the mornings between 05:00 and 06:30 when there's nothing on whatsoever and hot water and heating on the boiler were both off via the timer. The noise itself sounds like an artic lorry pulling up outside the house, I have a feeling it's the inlet pipe violantly resonating as the valve on the pipe has been slightly weeping following one of the longer episodes, the plumber has had to replace a valve before due to the gauge filling up with water. As always with this type of problem it isn't reproducible, we're tried loads of permutations to try and reproduce it. The audio recording attached was taken on my iPad, the only time I've managed to capture the noise - hope it strikes a chord with someone out there who has had to deal with something similar. On hearing it my plumber hasn't heard such a sound before.
Noisy main cold water pipe, my plumber hasn't heard this before. to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
