Noisy RCD. - BG brand | on ElectriciansForums
Discuss Noisy RCD. - BG brand in the UK Electrical Forum area at ElectriciansForums.net
1Justin
Surrey
I thought I'd try a BG CU.
The RCD's are noisy under load. Perhaps 2KW sets them off, a buzz which is quite audible from a few feet away. I swapped the noisy RCD for the second (since that side was still unused when I worked this out), the other one is also noisy, but less so.
Both switch fine, measure up (disconnect) fine, Zs fine, and no signs of anything wrong, no smell, heat etc. - Just the noise.
Is this normal for a BG brand RCD? Does anyone have anything to offer, or should I take them back?
could be a fault on the circuit. i fit BG regularly and ain't never herd them buzz, but then again, i'm a bitt mutton, so who knows? at least they not got recalls.
All connections are tight. I checked that already, but I will re-check since all the screws on thes BG (on the MCB's and the N E bar) are very stiff.
The load(s) which cause it may well be a bit inductive, because it's the heavy (heating) loads - eg kettle.
No dimmers.
Circuit all measures OK
The buzz under load is low level, but noticeable in quiet space.
It sounds like slight 50Hz rattle - like you might get from a loose winding of a transformer.
Just had an idea, I could pop the RCD into my own CU to try it, maybe worth a go.
No dimmers.
are you sure about this statement justin?
Hi Glenn,
Well I don't know, but a kettle is heated with a ceramic wire coil. Not exactly a motor winding I know, but it's not going to be a pure resistor. Anyhow, clutching at straws here since Chopper posed the question.
"Clamping all the tails together?" I'm not with you on that one.
Hi Glenn,
clamp both the tails with a leakage clamp....any mA shown will be the leakage...i suspect those RCDs are near their limit....
It may be it's close to the tripping threshold or it may be there's something wrong with them. To be honest if there's no problems with the circuits I'd return them to the wholesaler for a warranty and get them to investigate the issue, bottom line is they shouldn't make a noise and the customer will probably complain sooner or later.
Hi Glenn, Hmm leakage. Firstly might a standing leak show up as significant offset in the break time between positive and negative cycles? (I see no big difference).
& Insulation resistance is very high.
I also don't have a current clamp - maybe I should have one, would be handy from time to time. Thanks.
Reply to Noisy RCD. - BG brand in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
